hi
i have 4 circle near together
i set curveColid to each other truly
i set Spring between them
but the Spring goal for input ask me 2 Point3D or line
by the way i set points of my 4 circles to the spring
when i run Step
nothing happen
when i search in solver moves i can see the moves but it doesn’t automaticaly set on my CurveColid
and didn’t show me a line as spring looklike Grasshopper
thanx
you know what
if at pure C# we cant get Graphical result like grasshopper , can i stick my curveColid to point of Spring
what is Lenght Goal in grasshopper at the C# code i use Spring it was true ?
how we can detect whats the Solver output Type
at my last topic dear @DanielPiker set List of Curve for answering me
all of the Output is by this type ?
thank you at soon i test it in My pure C# rhino plugin
@Mahdiar whats is the rule of the out put?
first of list is Curve
from 1 to end of list -1 is line ?
how can i understand what is the output type
in C# not grasshopper ( i’m plugin programmer )
ok you add 4 cuves
but return one curve array
what can i understand this solution
in C# we havent Curve array for input goal and we should add one by one
and you do this by helping Grasshopper
ok so now - we add 4 goals for circles and return just one Curve array in one element of GetOutput() method
after it exactly Curves method add springs one after one and i get a list of lines in many element of GetOutput() method
its very hard to understand
Each goal can return an object when its Output method is called.
This object could be a single item, a list or an array.
For example, a Spring(Length) goal returns the line between its endpoints
Also many goals simply return null as their output.
When you call GetOutput for your list of goals, you get a list containing the result of the Output method of each of the goals in the list.
