Im iterating through geometries, creating GUIDs for them, baking them into Rhino. Then using a Rhino Script to select the objects by the GUIDs and export them to an Obj.
What i want to do is give them (the geometries) a name (attribute name) so that when they are objs they have some information to them.
I’ve created name attributes but when assigned the baking process creates 49 instances, 7 objects and bakes and names them 7 times over to make 49 objects.
I dont know how to integrate the Names into the script, attached is the gh file and the code in the body any assistance would be appreciated.
I dont know where this part goes to make it all work:
Rhino.DocObjects.ObjectAttributes att = new Rhino.DocObjects.ObjectAttributes();
att.Name = objName;*
C# Code
private void RunScript(DataTree geometries, string objName, string directory, string filename, bool export, ref object A)
if(export)
var guids = new List<Guid>();
for(int i = 0; i < geometries.BranchCount; i++)
for(int n = 0; n < geometries.Branches[i].Count; n++)
att.Name = objName;
var geom = geometries.Branches[i][n];
var guid = Rhino.RhinoDoc.ActiveDoc.Objects.Add(geom, att);
guids.Add(guid);
Rhino.RhinoDoc.ActiveDoc.Objects.Select(guids);
string filepath = Path.Combine(directory, filename);
string cmd = "_-Export " + "\"" + filepath + "\"" + " _Enter _Enter _D";
Rhino.RhinoApp.RunScript(cmd, false);
//Rhino.RhinoDoc.ActiveDoc.Objects.Delete(guids, true);
Thank you
ExporterTest.gh (8.5 KB)
