C# Editor doesn't find my local dll
Hello @eirannejad
I am using the new c# editor with Grasshopper in Rhino 8. I want to include some library (dll). I put this library on the same folder as the script
I do that
and it works.
On a same component I did that on a previous session it file is not found
On these component I put earlier an absolute reference but as I work for a client he has not the folder as me.
Is there a way to ensure that it keeps looking on current folder ?
The assembly must be loaded in Rhino if you are referencing it like # r "Name.dll". Currently Grasshopper scripts can not reference assemblies and modules alongside Grasshopper document.
I have a ticket to improve this
RH-81129 Scripts to search for modules/asse,mblies in Grasshopper document directory
Thanks for your answer, but I don’t understand
How to do that ?
@laurent_delrieu I am not sure how you are sharing the dll. Ideally it should be in a shared location and the absolute be added to the #r reference.
I have the YT ticket above to fix relative paths
