I need to move a grip indirectly through an MFC slider. I’ve followed @dale’s SampleMoveGrips to do this.
The problem is that it calls CRhinoObjectGrips::NewObject()
for every event of the slider being dragged, while CRhinoObjectGrips::Draw()
is never called.
I’d like to have this mechanism:
- Slider being dragged:
is called every time. NoCRhinoObjectGrips::NewObject()
, no data added to Rhino’s undo stack. - Slider dropped:
is called once. This final configuration is stored in Rhino’s undo stack.
My reasons to do this are memory related: handling pretty big meshes through custom grips, I cannot store undo data when dragging UI controls except once dropped. Also, triggering CRhinoObjectGrips::Draw()
would be great.
Any idea on this? There’s CRhinoGripObject::DragGrips()
but it calls CRhinoGripObject::MoveGrips()
which does what I referred in the above sample.
I know display conduits might be a solution but I want to know if it’s possible through grips (because of their tremendous capabilities like selecting grips, transforms, etc).
Thank you very much,
Pablo
