Hey there,
I’m trying to create a C# component, where you input two curves and divide them x times.
The Points on the curves should be the vertices for a quadrangular mesh.
Although the preview doesn’t look that bad i get an invalid mesh as output.
The exact statement is:
Mesh: ON_Mesh.m_F [4] .vi[ ] has invalid vertex indices.
Thanks for your help!
Lukertplugintest4.gh (5.6 KB)
The Code:
private void RunScript(Curve iCurve1, Curve iCurve2, int iSegments, ref object Mesh, ref object Vertices, ref object Validity)
List<Point3d> ptsCurve1 = new List<Point3d>();
List<Point3d> ptsCurve2 = new List<Point3d>();
Point3d ptCurve1 = new Point3d();
Point3d ptCurve2 = new Point3d();
double spacing = 1.0 / iSegments;
double t;
// divide curves
for (int i = 0; i < iSegments; i++)
t = i * spacing;
ptCurve1 = iCurve1.PointAtNormalizedLength(t);
ptsCurve1.Add(ptCurve1);
ptCurve2 = iCurve2.PointAtNormalizedLength(t);
ptsCurve2.Add(ptCurve2);
// reverse list if indices are on the wrong side
if (ptsCurve1[0].DistanceTo(ptsCurve2[0]) > ptsCurve1[0].DistanceTo(ptsCurve2[iSegments - 1]))
ptsCurve2.Reverse();
Mesh mesh = new Mesh();
mesh.Vertices.Add(ptsCurve1[i]);
mesh.Vertices.Add(ptsCurve2[i]);
for (int i = 0; i < mesh.Vertices.Count; i += 2)
mesh.Faces.AddFace(i, i + 1, i + 3, i + 2);
Mesh = mesh;
Vertices = mesh.Vertices;
Validity = GH_Format.FormatMeshValidity(mesh);
At first you’ve actually culled end points of your both curve’s division (when your segments integer is divided by 1.0 ) so when you make vertices from your segments integer it has two more extra point .
just subtract verticesCount from 2.0 for making faces .
double t;
// divide curves
t = i * spacing;
for (int i = 0; i < mesh.Vertices.Count - 2.0 ; i += 2)
Mesh = mesh;
Hi, you do not need to keep all those points. You can go directly to verts. Also @sagkoyeou fix leaves the last mesh face off:
Lastly there is some stuff you should typically do to meshes afterward for them to display well. Recomputing normals.
// orient curves
if (iCurve1.PointAtStart.DistanceTo(iCurve2.PointAtStart) > iCurve1.PointAtStart.DistanceTo(iCurve2.PointAtEnd))
iCurve2.Reverse();
// mesh
// spacing
double t;
// verts
for (int i = 0; i < iSegments + 1; i++)
t = i * spacing;
mesh.Vertices.Add(iCurve1.PointAtNormalizedLength(t));
mesh.Vertices.Add(iCurve2.PointAtNormalizedLength(t));
// faces
for (int i = 0; i < iSegments * 2; i += 2)
// finishing
mesh.Normals.ComputeNormals();
mesh.FaceNormals.ComputeFaceNormals();
mesh.Compact();
// outputs
Mesh = mesh;
Mesh2Curves.gh (9.1 KB)
