Hi there,
I know this is a totally Rhino-free question, but I need some help here.
I am trying to create a heatmap from int values or string values.
Therefore I am creating a class with 2 constructors that then “fire” an initializer.
When I use the the first constructor Heatmap(List<System.Guid> objs, List<int> values) everything is fine. Yet the other Heatmap(List<System.Guid> objs, List<string> criteria) is resulting in nothing at all. Even breakpoints are not indicating anything, the object simply is not initialized.
Any ideas?
Thanks,
T.
public Heatmap(List<System.Guid> objs, List<int> values)
Start(objs, values);
public Heatmap(List<System.Guid> objs, List<string> criteria)
List<string> set = criteria.Distinct().ToList();
List<int> result = criteria.Select(x => set.IndexOf(x)).ToList();
Start(objs, result);
public void Start(List<System.Guid> ids, List<int> values)
… No C# expert here …
But your code seems to work fine.
using System;
using System.Collections.Generic;
using System.Linq;
class Heatmap
for( int i = 0; i < 3; i++ )
Console.WriteLine( $"Guid {ids[ i ]}, Int {values[ i ]}" );
class main
static void Main()
var g = new List<System.Guid>();
g.Add( Guid.NewGuid() );
var i = new List<int> { 11, 22, 33 };
var s = new List<string> { "AA", "BB", "CC" };
Console.WriteLine( "(0)" );
var h1 = new Heatmap( g, i );
Console.WriteLine( "(1)" );
var h2 = new Heatmap( g, s );
Console.WriteLine( "(2)" );
Output:
c:\mono>tob1
(0)
Guid 9a477e86-7b57-4dd8-b5b8-507053f73048, Int 11
Guid 0d14639f-93e1-4610-913a-74c76e2af997, Int 22
Guid 6ae552c4-b2a2-4aea-9263-e8aaa0bbfb68, Int 33
(1)
Guid 9a477e86-7b57-4dd8-b5b8-507053f73048, Int 0
Guid 0d14639f-93e1-4610-913a-74c76e2af997, Int 1
Guid 6ae552c4-b2a2-4aea-9263-e8aaa0bbfb68, Int 2
(2)
c:\mono>
… Maybe something in the Start() method ?
Or in the data you’re using to initialize ?
