C# compiler crash when assigning value to object variable
I’m experiencing a hard rhino/Grassshopper crash when trying to run the following simplified code in the Gh C# editor;
  public class Cell
    //PROPERTIES
    public double test
      get{return test;}
      set{test = value;}
And in the body of the script
    Cell f = new Cell();
    f.test = 100;
This does not happed when using the short syntax for get and set.
I couldn’t find anything on the forum that was similar. I’m fairly new to C#. Minimal file attached - be sure to disable solver before opening as on my system it triggers a crash straight away. Apparently I’m working with .Net version 4.0.30319.42000 and Rhino 7SR16.
Systeminfo dump;
Rhino 7 SR16 2022-3-2 (Rhino 7, 7.16.22061.03001, Git hash:master @ cc6be15b6ce31f6e0bdd60bc4ab637f70ad1ecd3)
License type: Educational, build 2022-03-02
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
  Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 12-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.84
        - Windows Main Display is laptop's integrated screen or built-in port
Secondary graphics devices.
  Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 12-23-2020 (M-D-Y).
        - Secondary monitor is laptop's integrated screen or built-in port
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 8x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 12-6-2021
  Driver Version: 30.0.14.7284
  Z-Buffer depth: 24 bits
  Total Video Memory: 6 GB
  C:\Users\PB\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.3.3.0\7\Fologram.IO.Rhino3d.Win7.rhp	"Fologram for Rhino"	2020.3.3.0
  C:\Users\PB\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp	"ElefrontProperties"	1.0.0.0
  C:\Users\PB\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp	"NVIDIADenoiser.Windows"	0.4.0.0
  C:\Program Files\Rhino 7\Plug-ins\Commands.rhp	"Commands"	7.16.22061.3001
  C:\Program Files\Rhino 7\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	7.16.22061.3001
  C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	7.16.22061.3001
  C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp	"Renderer Development Kit UI"
  C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	7.16.22061.3001
  C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	7.16.22061.3001
  C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp	"Grasshopper"	7.16.22061.3001
  C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	7.16.22061.3001
  C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp	"Displacement"
Set_Example.gh (2.9 KB)
I just tested a string type rather than an int/double and the proplem is still there.
This appears related to the setter, not the getter. Is it to do with the ‘value’ keyword?
The syntax is wrong, and you will get a stack overflow due to the setter calling itself. You need a backing field variable that has a different name than ‘test’.
Thank you so much for pointing me in the right direction - now I understand the examples I had looked at previously.
