Point3d FirstPoint = iPoints[iPoints.ClosestIndexInList(iStartPoint)];
a = FirstPoint;
For some reason I get this error:
Error (CS1061): ‘System.Collections.Generic.List<Rhino.Geometry.Point3d>’ does not contain a definition for ‘ClosestIndexInList’ and no extension method ‘ClosestIndexInList’ accepting a first argument of type ‘System.Collections.Generic.List<Rhino.Geometry.Point3d>’ could be found (are you missing a using directive or an assembly reference?) (line 58)
Which basically says, that data type List has not method called ClosestIndexInList. And that it does not take as an input the data type List. Which makes no sense:
Because ClosestIndexInList IS a List method
Because I never passed a List type as an input of ClosestIndexInList I passed in a Point3d type.
You can clearly see that ‘iStartPoint’ is a Point3d type!
Hi, note David says it is a “static” method.
Your iPoints is indeed an instance of Point3dList. However, a static method is not hanging under an instance but it is hanging from it’s original class, Point3dList in your case. As David says, ClosestIndex is just a method, so it’s hanging from an instance.
The code should look like this.
I am not sure I follow your explanation: I am using ClosestIndexInList which is, in fact, static. Meaning I don’t need to create an instance of a class to utilize it. In fact David says just that:
If I get this right, I should be able to just call it directly on a List<Point3d> type.
As in:
Point3d myPoint = new Point3d();
List<Point3d> myList = new List<Point3d> ();
myList.ClosestIndexInList(myPoint)
Hi, maybe I was not right and a static method can be called via an instance.
But all of those methods are the methods of Point3dList, which is different from List.
You need to create a Point3dList from a List first. Point3dList is hanging from Rhino.Collections.
The inputs are specified as generic IEnumerable meaning you can feed either List or Point3dList. But the methods themselves are the methdos of Point3dList, not List
You are confusing a list of Point3d with the Point3dList class confusing naming but not the same thing. You can imagine the Point3dList class like a group. It lets a list of points be treated like a single object so you can do things to the points without iterating.
Yes! I was just starting to realize that by looking at the documentation. Thanks!
What I don’t get is what David said, that I can use ClosestIndexInList and ClosestPointInList on other collections such as List <Point3d>. Is that a fair statement if first I need to convert my List<Point3d> into a Point3dList?
That means the first parameter of
Rhino.Collections.Point3dList.ClosestPointIndexInList(param1,pnt);
does not need to be Point3dList but can also take List
Heeeey, now I realized why ShunnSup never understood what I was trying to say.
By some reason, “LIst< Point3d >” was cleaned by the forum system and only “List” was shown. Why is this??
