This is a simple example calling https://yesno.wtf/api from a c# component in GH:
var request = System.Net.WebRequest.Create(@"https://yesno.wtf/api");
request.Timeout = 1000;
request.Method = "GET";
try
using (var response = request.GetResponse())
using (var stream = response.GetResponseStream())
var reader = new StreamReader(stream, System.Text.Encoding.UTF8);
Print(reader.ReadToEnd());
catch (System.Net.WebException e)
Print(e.Message);
RestApiExample.gh (5.9 KB)
This example doesn’t need an api key. In your case, I suppose that would go in the headers:
request.Headers.Add("x-api-key", "your api key");
You might also want to add the content type:
request.ContentType = "application/json";
Finally, to parse the response, I’d recommend using Json.net and creating a class that matches the properties of the response. Something like:
public class OpenSensorMessage
public int date {get; set;}
public int rssi {get; set;}
public bool lowBattery {get; set;}
public bool heartbeat {get; set;}
public int lsnr {get; set;}
public string id {get; set;}
public string type {get; set;}
public string deviceId {get; set;}
public List<string> tags {get; set;}
