C# cage edit
#1
Is it possible to access cage editing functionality via c#? I found some stuff that looks promising in the CustomGrips documentation, but no examples or detailed documentation.
Basically, I need to create a cage, assign an object to transform, move the cage points around, and update the object all via c#.
#2
And a follow up question: Are there any restrictions on the topology of the cage? Can you generate a cage (or least grips for deformation) from any set of points?
(Steve Baer) #3
I don’t believe RhinoCommon currently has support for the cage editing. I’ve added this as a feature request to our bugtracker
http://mcneel.myjetbrains.com/youtrack/issue/RH-21498
#4
Great, thanks!
