C# Brep Split
Could you please help me solve the Brep Split in C#, when I use the example bellow I get 2 clones of the object I want to split, plus the original.
All I want to achieve is a regular split.
Thank you!
            ///This is for testing splitting of surfaces
            ObjRef srfRef;
            Result result = RhinoGet.GetOneObject("Pick surface to split", false, ObjectType.Surface, out srfRef);
            if (result != Result.Success)
                MessageBox.Show("Couldn't pick surface to split");
                return;
            var srfBrep = srfRef.Brep();
            ObjRef splitRef;
            result = RhinoGet.GetOneObject("Pick splitter", false, ObjectType.Surface, out splitRef);
                MessageBox.Show("Couldn't pick splitter");
                return;
            var splitBrep = splitRef.Brep();
            splitBrep.Flip();
            var breps = srfBrep.Split(splitBrep, Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance);
            foreach (var brep in breps)
                foreach (var bsurf in brep.Surfaces)
                    Rhino.RhinoDoc.ActiveDoc.Objects.Add(bsurf);
Hi Cristiane,
In order to add the brep with the trimming information created by split, you will need to add the brep and not the underlying untrimmed surfaces (brep.Surface). Iā€™m not familiar enough with C# but the pseudo code I think should be:
foreach( var brep in breps):
    Rhino.RhinoDoc.ActiveDoc.Objects.AddBrep(brep)
HTH
-Willem
It works!
Thank you very much for your help!
Cristina
