C++ Add layer changed syntax
I am following this tutorial to add child layer, but the syntax of Current Rhino SDK was changed:
I tried to write something like this and I have one error in line
child_layer.SetParentLayerId(layer.Id);//Error C2276 '*': illegal operation on bound member function expression
also tried:
child_layer.SetParentLayerId = layer.Id; // Error C2659 = function as left operand
How can I correctly change parent layer id?
CRhinoCommand::result CCommandLearning180704::RunCommand(const CRhinoCommandContext& context)
	CRhinoLayerTable& layer_table = context.m_doc.m_layer_table;
	//Define parent layer
	ON_Layer parent_layer;
	parent_layer.SetName(L"Parent");
	//Add parent layer
	int parent_layer_index = layer_table.AddLayer(parent_layer);
	if (parent_layer_index >= 0) {
		//Get the layer we just added
		const CRhinoLayer& layer = layer_table[parent_layer_index];
		//Define child layer
		ON_Layer child_layer;
		child_layer.SetName(L"Child");
		//Assign parent layer's id as child's parent id
		//Add child layer
		layer_table.AddLayer(child_layer);
	return success;
probably you need to call a function layer.Id() or use member variable layer.m_layer_id
@Petras_Vestartas, I’ve updated the guide. Please revisit the page…
– Dale
Thanks Dale and Menno, the only issue was that I wrote: layer.Id isntead of layer.Id()
Each time I see id, count, or name it seems to me as variable but in c++ rhino sdk it is always a method.
method function :slight_smile:
It is a method
I stand corrected :slight_smile:
