Bypass "get" Input in GH
how do i bypass getnumber or getinteger or getpoint (any “get” input) from grasshopper in the prompt window when executing GF player?
i tried using Gate filter with Null fed into the component. but it still doesnt “skip” the prompt.
The “get” containers for GrasshopperPlayer are not that advanced. The prompts are made in the vertical order of the containers on the canvas, and that’s it. (The developers could improve it, but they don’t. They just kind of included it as a half-baked implementation.)
The best you can do, is force the user through all the prompts, and not use the containers that are irrelevant.
ah i see. i think this “get” input can be further explored. because it is essence of GHplayer. thanks mate for the fast response
Geometry Pipeline with preselected objects. Personally I use in conjunction with a Data recorder and a Create Set/Member Index components to be able to deselect after launching the definition.
I don’t understand. Can you give an example of the workflow?
Im also curious on what u mean by this mate. can help post an example or explain a little more detail?
One of these should do the trick. You need to have the objects preselected, before launching the definition.
Bypass_Get_Obj.gh (133.2 KB)
