Also, Adjusting the contrast is necessary but for backgroundbitmap style use, I find adjusting transparency works well for this, so I am not sure we absolutely need that explicit control.
Unfortunately your comments were hard to find. I’m not sure where the best place is to comment but so far everyone is adding them here… so that others can respond.
I added some more comments there. Hopefully everyone will be able to find them.
I’m not sure what the technical name of the controls are, but so far it seems like we have suggestions for a few different controls that all do about the same thing… that is make the image get out of the way of what you are modeling.
@bobmcneel Here’s what it would take to replace the background bitmap with a picture frame implementation. I’m assuming that you would run the BackgroundBitmap command and get a picture frame object that is similar in functionality for tracing. This would be something like:
Create PictureFrame
SendToBack
Lock (maybe)
Only Visible in One Viewport
http://mcneel.myjetbrains.com/youtrack/issue/RH-187
This is really a general issue that has been requested for all object types (the ability to have objects only visible in specified viewports.) Technically the functionality already exists; it is a matter of figuring out a user interface to make this work in a way that doesn’t make you insane. I would rate the UI part as a significant amount of work because an obvious solution isn’t coming to mind.
All that said, I’m not sure that single viewport visibility is really needed for picture frame replacement of background bitmap.
Edges Show on Picture Frames
Not drawing edges for picture frames is technically very easy for Jeff or me to implement (< 1 hour). If we always want to not draw edges, this is simple. If we sometimes do not draw edges, then this becomes a user interface issue that we would need to figure out.
Always in back
http://mcneel.myjetbrains.com/youtrack/issue/RH-12677 The display order commands would need to be tuned up to handle things like picture frames. Turning this feature on is not technically difficult. The technical difficult part is figuring out what to do if the user tweaks the picture frame so it becomes non-planar.
Grayscale, Filter
Converting an image to grayscale is technically not difficult. If the BackgroundBitmap command handled the grayscale, it could just convert the image before a picture frame was added. If we wanted to turn gray on/off, we would need to add something to the user interface. Filter is also something we probably don’t have exposed in the user interface. Probably something along the lines of what @andy proposed in his initial reply.
Don’t Render
BackgroundBitmaps don’t render. For users to do this with PictureFrames, they would need to run the Hide command. That seems like a more obvious solution than coming up with some weird special case.
1 To 1 Scale
Adding this as an option to the PictureFrame command should be technically simple.
Other Things to Consider
If BackgroundBitmap were removed…
Would need to remove the option to print this from the print dialog
What I wrote about above doesn’t work if you wanted to run BackgroundBitmap a second time and expect to be able to tweak things
This affects training and documentation (may not be a bad thing)
theoutside
(Kyle Houchens - McNeel and Assoc. )
#40
transparency is already implemented in teh material UI
1-1 would be an add
self illumination is already implemented as enable diffuse lighting in teh advanced tab? (is this correct?)
display behind is not needed as you can set this interactively by where it’s placed in the scene
show in one view is IMO mnot needed since it can only face one direction at a time, it will only show up in one view unless it placed at a non world axis angle- in that case it would be fair to assume that the user wanted it ot be seen in more then one viewport-
If we are going to impact documentation, why not change the command name so that is better matches reality? This seems like something @mary and @margaret should comment on.
I have already moved the User’s Guide tutorial about tracing images to using PictureFrame instead of BackgroundBitmap. Somewhere along the way, Pascal suggested a name that included the word “image.” I thought this was a good name, but now I can’t remember it. For the simple example in the User’s Guide, I’ll bet just swapping out the command name will do the trick.
I have no idea why we are moving away from PictureFrame as a name. Those two works are ordinary works. Image & Plane are both geeky words. Do you go out with your camera to take some images? What do you put on your wall - “planes” ? If anything, I would ditch the “Frame” part and just call it “Picture” - in the same way that a curve is a curve, and a surface is a surface.
Also - the question of whether it should render by default - and print…I say yes. It should do both. Because if something renders or prints and the user decides they don’t want it, they will think “how do I turn this off”. If something fails to render or print, they will think “this is broken”.
Having per-object “Render” and “Print” properties would be an excellent way to solve this. They would be very easy to implement, and would be a very useful feature.
And hiding them is not the same - because then they don’t show in the display either - which is the point. You want them to display, but not get output.
I have always found this to be a lack with detail viewport edges. I don’t want them to print, but I want to see them in the viewport.
Incidently, the “Picture” material type is in process. We should have something checked into V6 pretty soon. I think its a good idea even without the change to PictureFrame.
