Dear community,
I am trying to build up geometries in Rhino. That means I try to create full patches with trimming information. I coded the following script, in the end all data seems to be correct but the Brep is still unvalid. When I check every entry it is valid. But in the end I am not able to create an entire patch with trimming information
Is there somebody who could maybe help me? Thanks!
I took the whole code with also the hashtables where I get the data from.
var thisBrep = new Brep();
var breps = RhinoVisualizerPlugIn.Instance.geometry["breps"];
foreach (var brep in (IEnumerable)breps)
var facesArray = (brep as Hashtable)["faces"];
foreach (var faceElement in (IEnumerable)facesArray)
var one_face = (Hashtable)faceElement;
var surface = (Hashtable)one_face["surface"];
var degrees = surface["degrees"];
var degreeList = (from object u in (IEnumerable)degrees select Convert.ToInt32(u)).ToList();
List<List<double>> knot_vectors = new List<List<double>>();
foreach (var knot in (IEnumerable)surface["knot_vectors"])
var knots = (from object u in (IEnumerable)knot select Convert.ToDouble(u)).ToList();
knot_vectors.Add(knots);
Dictionary<int, List<double>> control_points = new Dictionary<int, List<double>>();
List<int> ids = new List<int>();
foreach (var cp in (IEnumerable)surface["control_points"])
var one_cp = cp as ArrayList;
int id = Convert.ToInt32(one_cp[0]);
var locations = (from object u in (IEnumerable)one_cp[1] select Convert.ToDouble(u)).ToList();
control_points.Add(id, locations);
ids.Add(id);
int degree_u = degreeList[0];
int degree_v = degreeList[0];
int control_points_u = knot_vectors[0].Count - degreeList[0] + 1;
int control_points_v = knot_vectors[1].Count - degreeList[1] + 1;
var nurbSurface = NurbsSurface.Create(3, true, degree_u + 1,
degree_v + 1, control_points_u, control_points_v);
if (nurbSurface != null)
for (int u = 0; u < nurbSurface.KnotsU.Count; u++)
nurbSurface.KnotsU[u] = knot_vectors[0][u];
for (int v = 0; v < nurbSurface.KnotsV.Count; v++)
nurbSurface.KnotsV[v] = knot_vectors[1][v];
for (int u = 0; u < nurbSurface.Points.CountU; u++)
for (int v = 0; v < nurbSurface.Points.CountV; v++)
var ControlPointID = u * nurbSurface.Points.CountV + v;//(knot_vectors[1].Count - degreeList[1] + 1) + v;
nurbSurface.Points.SetControlPoint(u, v,
new ControlPoint(control_points[ids[ControlPointID]][0], control_points[ids[ControlPointID]][1],
control_points[ids[ControlPointID]][2], control_points[ids[ControlPointID]][3]));
int surfaceIndex = thisBrep.AddSurface(nurbSurface);
BrepFace face = thisBrep.Faces.Add(surfaceIndex);
foreach (var boundary_loop in (IEnumerable)one_face["boundary_loops"])
var one_boundary_loop = (Hashtable)boundary_loop;
if (Convert.ToString(one_boundary_loop["loop_type"]) == "inner")
BrepLoop rhinoLoop = thisBrep.Loops.Add(BrepLoopType.Inner, face);
else
BrepLoop rhinoLoop = thisBrep.Loops.Add(BrepLoopType.Outer, face);
foreach (var trimming_curve in (IEnumerable)one_boundary_loop["trimming_curves"])
var one_trimming_curve = (Hashtable)trimming_curve;
Hashtable one_parameter_curve = one_trimming_curve["parameter_curve"] as Hashtable;
int degree = Convert.ToInt32(one_parameter_curve["degree"]);
var parameter_knot_vector = (from object u in (IEnumerable)one_parameter_curve["knot_vector"] select Convert.ToDouble(u)).ToList();
List<List<double>> parameter_control_points = new List<List<double>>();
foreach (var cp in (IEnumerable)one_parameter_curve["control_points"])
var one_cp = (from object u in (IEnumerable)cp select Convert.ToDouble(u)).ToList();
parameter_control_points.Add(one_cp);
NurbsCurve nurbCurve = new NurbsCurve(2, true, degree + 1,
parameter_control_points.Count);
for (int i = 0; i < nurbCurve.Knots.Count; i++)
nurbCurve.Knots[i] = parameter_knot_vector[i];
for (int i = 0; i < parameter_control_points.Count; i++)
nurbCurve.Points.SetPoint(i, parameter_control_points[i][0], parameter_control_points[i][1],
parameter_control_points[i][2], parameter_control_points[i][3]);
int curve2DIndex = thisBrep.Curves2D.Add(nurbCurve);
Curve curve3D = nurbSurface.Pushup(thisBrep.Curves2D[curve2DIndex], 0.001);
int curve3DIndex = thisBrep.Curves3D.Add(curve3D);
BrepVertex firstVertex = thisBrep.Vertices.Add(curve3D.PointAtStart, 0.001);
BrepVertex lastVertex = thisBrep.Vertices.Add(curve3D.PointAtEnd, 0.001);
BrepEdge edge = thisBrep.Edges.Add(firstVertex, lastVertex, curve3DIndex, 0.001);
BrepTrim trim = thisBrep.Trims.Add(edge, false, rhinoLoop, curve2DIndex);
trim.TrimType = BrepTrimType.Boundary;
trim.SetTolerances(0.001, 0.001);
thisBrep.SetTrimIsoFlags();
doc.Objects.AddBrep(thisBrep);
