Hi everyone,
i´m new in this Forum and also in Rhino (use it since two weeks). My current aim is it to build parts only by writing commands in Excel-files and copy them in the Rhino command prompt. An easy example is in the attachment.
Now my questions:
- When i use the command sweep1 a window opens. How can i avoid this with previously defined settings? Because it´s a bit annoying when i have to use this command often for one part.
- To close the openings of the polysurfaces i want to use the commands SplitEdge, BlendSrf and Join. For SplitEdge i have to select one edge of the polysurface and following i want to split the edge at the midpoint. How can i select one edge and the midpoint via commands?
- For BlendSrf i have to select the segments of the splitted edge. Same Question. How can i do this via command? Furthermore i want to avoid the window opens with previously defined settings (for example: position and position).
- Now i want to delete the ends of the horizontal part till the vertical parts (command moveface toboundary). How can i select the top surface of the horizontal part and the surface of the vertical part?
Do i need Python skills for this? Currently i have no experience with Python.
I would really appreciate your help.
Example.3dm (61.0 KB)
commands.txt (1.9 KB)
Best regards
Felix
