I selected my NAS, created a new folder, gave a new filname. SAVED, but the filename didn’t appear in the top of Rhino. There was only “Ohne Titel — Bearbeitet” (DefaultFileName).
I looked up the in Finder, but there also was no file.
The I exported as dxf without problems. The ExportFile had been saved in correct Folder.
I cannot duplicate what you are describing, but your description is not clear enough to know what you have done. “SAVED” does not tell me what command or menu choice you used to save your model, nor did you describe that you filled in the contents of the Save file dialog.
I’ll need a much more detailed set of instructions to be able to duplicate your problem. This article can help.
