you can insert the BackGroundImage, but then Cancel or done Buttons are out of order/function. Then you are in a deadlock. ESC or other buttons bring up a SystemSound. As You can see, I use the german Version.
Thanks for help
CaJoDo
Thanks for help
CaJoDo
I believe the is due to using the Done button versus pressing Enter to complete the command. This is filed as a bug already. I’m not sure if it will help but PictureFrame may be of interest too if you’re tracing images. Please let me know if I’m incorrect about the use of the Done button when you see this issue.
