while typing a command into a defined shortcut space the focus gets moved from the input box to the command bar after each letter making it rather impossible to set up a shortcut.
2.
also the set shortcuts seem to be ignored. i used for instance CMD ALT R setting it to '_SetDisplayMode _Raytraced the command neither shows up nor seems to work, when i copy the command into the command bar the command works.
that is what i entered, but the command is ignored, nothing happens}
and here it does not show up, i believe it should.
also as explained in a different topic, these commands which are set up here as wireframe, shaded etc are not accessible in the keyboard section, so its neither possible to change these and it is also not possible to set any command with CMD CTRL + these are missing entirely.
