Hi there
I Had some fun in Rh7 (7.0.20154.14355), but I found some bugs:
have you changed the boolean difference? It did not work with a Nurmbs part (done with Subd) where I wanted to cut out some small parts. I copied everything to Rhino 6 and it worked. Sorry that I cannot send a file for this one.
-Continuing the discussion from Bugs on RH7 WIP: -
Strange results with the Text object tool. It is Arial size 0.7mm
and a wish:
When I have lots of layers and click them on and off it the view jumps to the top of the list. So if if push several times at the same place I turn on and off diffferent layers. This is really disturbing and different from Rh6. Please check
