8.35.26251.13001, 2026-09-08
9.0.26286.06303, 10/13/2026
Bug 1
Given a text object with text:
a12/34/56/78c
e78/12/34/56o
r56/78/12/34s
with all characters typed as shown, i.e., no copy/paste was used,
the following are _FindText settings and results from each:
Find:12/34 or 12\/34
Replace:99/00
Match case and Whole word are both unchecked.
Result showing what appears to be an off-by-one error on both lines 2 & 3:
a99/00/56/78c
e78/199/0056o
r56/78/199/00
Find:(?m)^([^\S\r\n]*.*?)(12\/34)(.*)
Replace:${1}99/00$3
Result has all 3 correct replacements, but 3 spaces were added to the beginnings of lines 2 & 3:
a99/00/56/78c
e78/99/00/56o
r56/78/99/00s
Bug #2
Another bug is how formatting is not retained when the characters themselves have local font overrides applied within the Edit Text dialog. For example, the fonts of both text objects were changed from Arial to Consolas as follows:
- Lower text object: Setting
FonttoConsolasin the Properties panel. - Upper text object:
- Double-clicking the text to open
Edit Textdialog - All text is selected by default (otherwise, use Ctrl+A).
- Setting
FonttoConsolas.
The upper text object loses its font setting.
FindText.3dm (55.0 KB)
