In 7.38, 8.35, and 9.0.26279.6303, 10/6/2026
Bugs:
The non-overload GetNextDiscontinuity documentation does not state what values are used to determine the thresholds of G1 and G2 discontinuities, but the overload GetNextDiscontinuity documentation states they are
cosAngleTolerance: cos(1 degree) curvatureTolerance: ON_SQRT_EPSILON (|K0 - K1| > curvature_tolerance)The reality is that
cos(1 degree) is used for G1<- Good
but the thresholds for G2 are
A. 2.0°<- Should be 1.0° (_GCon uses the same angle for both G1 and G2 thresholds, so correcting this will also make GetNextDiscontinuity more consistent with _GCon.)
B. Relative difference in magnitude (RDM) of 5%,
where RDM = abs(kB - kA) / max(kB, kA)<- Documentation should state that the relative difference of 5% is the default. -
Overload GetNextDiscontinuity bugs
A. cosAngleTolerance:
G1 results honor the argument.
However for G2,
Cos(0.0) <= cosAngleTolerance <= Cos(1.0): The threshold is actually for 2.0°.
cosAngleTolerance=Cos(1.001 deg): Threshold at 2.002°
cosAngleTolerance=Cos(7.494 deg): Threshold at 14.988°
cosAngleTolerance >= ~Cos(7.495 deg): No G2 discontinuities are found.
Fix would be for G2 to honor the argument value, like it already does for G1.
B. 0.0 <= curvatureTolerance <= ADM (variable) (absolute difference in magnitude that results in 5% relative difference in magnitude)
ADM < curvatureTolerance <= ?: absolute difference is honored
? < curvatureTolerance: No G2 discontinuities are found.
Fix would be to change curvatureTolerance to be the relative difference in magnitude, and have it honor all values >= 0.
GetNextDiscontinuity G2 direction bug and comparing against _GCon
For_GetNextDiscontinuity_G2_direction.3dm (78.3 KB)
IronPython 2 script for GetNextDiscontinuity for provided .3dm
#! python 2
from __future__ import absolute_import, division, print_function, unicode_literals
import Rhino
from System import Math
def main():
res, objref = Rhino.Input.RhinoGet.GetOneObject(
prompt="Select curve",
acceptNothing=False,
filter=Rhino.DocObjects.ObjectType.Curve)
if res != Rhino.Commands.Result.Success: return
crv = objref.Geometry()
rv = crv.GetNextDiscontinuity(
continuityType=Rhino.Geometry.Continuity.G2_continuous,
t0=crv.Domain.T0,
t1=crv.Domain.T1,
cosAngleTolerance=Math.Cos(Rhino.RhinoMath.ToRadians(1.0)),
curvatureTolerance=Rhino.RhinoMath.SqrtEpsilon)
print(rv)
if __name__ == '__main__': main()
Then, _Explode the 4 curves into pairs and _GCon check the continuity of each pair.
