then why would that be the problem? also that means that all geometry created by sweep2 and option point at the ends for instance will be creating issues for further processing, i wonder if there is nothing the developers can do?
Explode the model. Create “Sweep 2 rails” with the “Position” option. Then apply “Match surface” with the following settings:
“Continuity: Tangency”
“Match edges by closest points”
“Preserve isocurve direction”
“Distance: 0.001 units”
