using Layout to create 2d view from my 3D model I get weird result, both in Rhino 6 and 7 (see attached)
Also, color on section appears only if I activate shadow.
LayoutBug.3dm (11.1 MB)
Hello - Unfortunately, there are no detail views in the layout of the file you posted - can you try again?
you are right, sorry
I’ve deleted the layers with the layout
sorry, my mistake
LayoutBug.3dm (13.2 MB)
Hello - no… in your image, is the current display mode for the layout itself set to wireframe? It is, here, it just looks like maybe it is set to something else in your image.
Yes, for the layout is set to wireframe, all detail view are in pen mode.
If I try to switch layout from wire to any other type, the issue still remain.
It looks like the page rectangle itself, the ‘paper’ has got out of place somehow - can you please run SystemInfo
in Rhino and post the result?
here you are
Rhino 7 SR0 2020-4-21 (Public Build, 7.0.20112.12445, Git hash:master @ 86276bc12c444fd48d1645bda74a385a1118fb03)
License type: Valutazione, build 2020-04-21
License details: Cloud Zoo
Expires on: 2020-06-05
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Non-hybrid graphics.
Primary display and OpenGL: Intel® HD Graphics 620 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y). OpenGL Ver: 4.6.0 - Build 26.20.100.7263
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 26.20.100.7263
Driver Date: 9-25-2019
Driver Version: 26.20.100.7263
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7 WIP\Plug-ins\Commands.rhp “Commands” 7.0.20112.12445
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7 WIP\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20112.12445
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20112.12445
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.0.20112.12445
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20112.12445
C:\Program Files\Rhino 7 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20112.12445
C:\Program Files\Rhino 7 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7 WIP\Plug-ins\Displacement.rhp “Displacement”
Hello - the video drivers are not exactly old but I would nonetheless update them to the latest available from the Intel website.
updated the driver…
“…Primary display and OpenGL: Intel® HD Graphics 620 (Intel) Memory: 1GB, Driver date: 4-11-2020 (M-D-Y). OpenGL Ver: 4.6.0 - Build 26.20.100.8141
Hm - OK, thanks. @stevebaer - do you have an idea? The layout view in the top post - shows the ‘paper’, if that is what it is, all askew. It looks fine here.
I have never seen this before. Maybe getting the display mode customizations would help to be able to repeat this.
Hi Nicola - can you please export the custom modes from the list and send the resulting ini files?
the problem appears also in world view:
when you open the file (attached at the beginning), you are in world view and it should be all ok;
then switch to layout and you should be able to see the issue, and also swithcing back to world view you have the following issue
Hi Nicola - I see two things in your images of the layout
Are you asking about one, or both, of these?
So far, I do not see the first problem here, nor the problem shown in your last note, with the clipped shading in model views.
Hi Pascal,
I can say that I’m first asking for the clipped shading, that appears both in layout and in model view
Second for the missing color in the section
For the missing lines I’ve just write in another thread, but for me it’s in any case an issue
I don’t know if they are all connected or not.
The issue appears also in the printed pdf from the layout
LayoutBug.pdf (2.3 MB)
I suspect the issue is caused by section plane, because it start to appears when I add them, but it’s only my feeling.
Are you still having this issue?
If so, please send a 3dm file and the specific details needed to repeat the problem.
Thanks
