Hi
I try Zoom Dynamic hotkey in Rhino 6 + 7 but it not work. When I try Alt + RMB. It work.
Please check
BETA (7.0.20295.18003, 21.10.2020)
It’s working, Ctrl + RMB
Hi
I use Window 10 and Wacom Pen. It’'s not work
With Wacom Pen we have LMB, RMB and MMB.
I tried Rhino 6 and BETA.
Hi
Any update for this issue?
Can not use Ctrl + RMB to zoom
Thank
Travis
Hi
Please check this bug, I can not zoom in 2D view.
Thank
Travis
Hi
Anyone check this issue?
Thank
Travis
I find that if you put your device in tablet mode (at least possible with windows 10) you can manipulate the viewport with pen RMB just as if you were using the mouse.
Hi @nathanletwory
Thank your feedback, what kind of tablet do you use?
How you custom pen buttons?
I use wacom intuos.
Thank
Travis
I have a small Intuos S (CTL-4100). I have the buttons on the side of the pen set to rmb and mmb (from tip up). The four buttons on the tablet from left to right set to ctrl, alt, shift, win.
Hi @nathanletwory
This is my custom
I active Tablet Mode as you suggest.
when I hold RMB, they can Pan in 2D view and Orbit in 3D view. I try hold Ctrl + RMB, can not zoom dynamic.
How can you zoom dynamic?
Thank
Travis
I don’t use Zoom for the larger button, but right-click. I noticed actually that Tablet mode doesn’t even have to be on then.
For completeness, here is my tablet setup
(I wanted same order of modifier keys as on the keyboard).
Hi @nathanletwory
I try set express key as you.
When I hold express key for Ctrl + RMB, they did not work.
When I use ALT + RMB, It can zoom dynamic in 3D View.
Ctrl + RMB
Alt +RMB
will not work in 2D.
Did you try zoom dynamic in 2D View?
Thank
Travis
Yes, it works for me. Did you also set the larger button to Right click instead of Zoom? The lower, smaller button I have set to middle click.
Hi @nathanletwory
I don’t think problem with set button, however I try setting as you:
it did not work.
Odd thing happening, May be we need one more Wacom user will give feedback in this case.
Travis
