Bug with Section Direction
Section is created in the opposite direction to the setting.
Thanks.
Hi @archist97 the section direction preview is not consistent when you click at some point on the section line while defining the section viewer position and length. Try to avoid snapping on the section line but to a point outside the section line, so you also have more control over the section length (depth).
In any case, you can always flip the section direction with one of its control points located next to the section arrows:
section line
I misunderstand the meaning of ‘Section Length’.
Thanks !!
Yes, maybe we should change the term for “Section Depth”
