Bug with rhinoscriptsyntax Arc helper functions
In Rhino 8 SR1 (8.1.23325.13001, 2023-11-21), rhinoscriptsyntax’s Arc helper functions seem to all raise a TypeError due to the TryGetArc function (TypeError: No method matches given arguments for Curve.TryGetArc: (<class 'float'>)). This can be resolved by not passing in Rhino.RhinoMath.ZeroTolerance, which seems to be redundant according to the RhinoCommon API.
I haven’t tried the Circle helper functions, but I suspect they might exhibit a similar issue.
What are these functions? Can you provide a code snippet that doesn’t work?
Are you using Python 2 or 3?
Thanks,
– Dale
I’m using CPython 3. The functions that don’t seem to be working are ArcAngle, ArcCenterPoint, ArcMidPoint, ArcRadius, CircleCenterPoint, CircleCircumference, CircleRadius (they’re all that I tested). The TryGetArc and TryGetCircle functions work just fine with no parameters which defaults the tolerance to RhinoMath.ZeroTolerance, but seemingly when that zero tolerance is passed in manually, the break.
Here’s a snippet that can recreate the issue.
arc = rs.GetObject("Select an arc")
# Fails due to TypeError: No method matches given arguments for Curve.TryGetArc: (<class 'float'>)
print(rs.ArcAngle(arc))
# Substituting in any of the other methods outlined also results in the same error
Hi @Russell_Newton,
Thanks - I’ve logged the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-78917
– Dale
