Sometimes, when I delete a node in Grasshopper (in this case, the Direct Geometry component), the warning if Revit saying an object is no longer being tracked will not pop up. This causes everything to stop working because both Revit and Rhino are waiting for you to address the warning before continuing.
Is there a way to see all warning pop ups in Revit or a possible way around this?
