Thanks, I see that here. A YT should get generated automatically from my crash and I’ll post the link when that comes in.
[Apparently, the auto-generated YT can’t be made public. On the list as RH-98897: Contour Command - Contour Command: com.mcneel.rhinoceros.RhCore:CCommandContour::RunCommand(CRhinoCommandContext const&)]
It looks like running Contour on a block instance that contains at least two objects reliably crashes Rhino 8. FWIW, this works fine in Rhino 9.
It is surprising that it works in V9 now. A couple of weeks ago, I discovered the bug in V8 and then it also crashed my V9 if I remember well.
So thank you for mentioning that it now works in V9. I’ll add that info in the training manual.
