Bug with complex surface
Hi everyone, so I have search but I can’t seem to find any answer to my problem so I will post it here:
I have a problem with a complex simple trimmed surface that represents roads in a city, I have some “holes” that appears in my surface and I can’t patch them or anything else, if someone has a solution that would be awesome !!
Here some pictures:
Ps : the surface is huge, I can’t untrim it it doesn’t work…
Hello - what does the Check command say about the object?
First thank you for answering so fast,
Then it says everything is fine
I have decided to transform it in a mesh, so it kind of work, but if you think about a solution to keep a surface it would be welcome !
Hello - can you please post a file with just the problematic surface?
Sure, here it is file.rar (7.5 MB)
I had to compress it because of size
Hello - as far as I can see Untrim works fine on this surface.
Yes, you are right but I don’t know what to do after the untrim, when I rebuild the cutting curve, or explode join, it becomes worse than before…
Hello - yeah some of the trims are messy - they have self-intersections for example-
I would DupBorder, SelSelfIntersectingCrv and Isolate then see if you can see where the problems are and fix them. The IntersectSelf command will help you locate these - you may need to look vary closely to see the problems.
Oh thank you!! I didn’t think about that it’s my fault I did some offset curves I thouht I had checked all of this self intersecting curves…
Thank you for your answers Pascal !!
Have a good day
Ps I didn’t know the SelSelfIntersecting tool …
Try typing SelSelfIntersectingCrv in the command window.
