having fun with 6 beta. when scaling several complex curves, all are highlighted, only some of the curves get scaled though. Works properly when using the gumball scale, but with a scaling window, the curves come apart.
While cleaning up my example file to send to you,
I am unable to replicate the error. What I noted
earlier was that a group of curves scaled
properly when using the gumball; when using scale
2d, some curves in the group scaled properly
while other did not. Again, I am unable to reproduce the error.
Hello - all that comes to mind is that some curves were copied or arrayed using History, and History locking was on, which would block editing the ‘children’. Or, possibly, that you were using Worksessions and some of the curves were not in the current file…
editing the âchildrenâ. Or, possibly, that
November 25
Thank you for your kind response. While cleaning
up my example file to send to you, I am unable
to replicate the error. What I noted earlier was
that a group of curves scaled properly when
using the gumball; when using scale 2d, some
curves in the group scaled properly while other did not. Aga
