VA objects become polysurfaces after running command extract surface on them
Furthermore, if you control z to get back to before the VA object became a polysurface, Rhino crashes.
I have tried this with Walls and Roofs VA objects, all similar results.
Rhino and VA latest update as of post date.
Hi @lourencovp thanks for reporting these issues. I’ll let you know when we fix them.
@lourencovp If you enable the Copy option in the Command line when running the ExtractSrf command, you will be able to extract the object surface without getting the exploded remains of the VisualARQ object.
ExtractSrf
