Bug: V8 WIP selection filters panel control
Kindly see below the normal workflow which is working as expected
but if I use alias command to replace clicking on disable to switch filtering or not, will see the restoration record seems to be eliminated.
please help to check the unexpected stuff, thanks!
What alias are you using for this?
Hi @Gijs , kindly see step 2 in the lower screenshot, I set a custom alias as “F” for " '_-selectionfilter _DisableFilter _enter ".
Hi @weekenlwk sorry, I missed that in the screenshots. I can repeat this (also in V7 btw)
The odd thing is that it only happens when all the filters are active, can you confirm this? For example, if you uncheck Others and then right click Curves, then enable/disable through the alias, then right click curves again, it reverts properly.
Thanks for testing. I used to use “showfilter” option to toggle the filter in V7, so not found this issue before :joy:.
I just tried my procedure first in V7 and it indeed happens here.
And I tried your way to repeat this, but the result is also the same as no restoration. I am not sure I did exactly what you did.
