BUG: V8 Lockup
I have repeatedly run into the problem where Rhino locks up when reading a file. Activity Monitor shows it in red. Killing takes a long time. Attached is a SEND TO APPLE from a recent event.
Rhino.txt.zip (297.7 KB)
Hi John -
Is there any pattern to this behavior? Is this file-specific?
Have you tried to let Rhino work on this for a longer period of time before force-quitting?
I’ve left it over night before.
I suspect the problem occurs when you accidentally export to yourself rather than to a PDF.
Thanks John -
I’ve put this on the list for a developer to take a look at → RH-81104 Rhino locks up when reading a file
Hi!
Would we be able to get the file?
You can send it to Rhino - Upload to Support - and set andy@mcneel.com as the recipient email address.
  • Andy
After a reboot, things go back to normal.
