BUG v8: Angular dimension jumps when block edit
Just opening block for edit makes dependent angular dimension to jump off without any changes made to the block.
angdimfail.3dm (191.5 KB)
Thanks, Ivan → RH-80816 History: Dimension position failure case
I see this with your file but am unable to reproduce this from scratch.
Hi Ivan -
As I wrote, I’m not able to reproduce this from scratch. The developer has reviewed the issue and says this can’t be fixed unless there are step-by-step instructions for getting to the state that the model is in at this point. Is this something that you see “all the time” and can provide such steps?
i ll check it later
create two lines, make one of them a block, add angular dim between them, move angular dimension dimension arc grip, open block hit save edit and see.
i tried it only happens once you move arc grip …
RH-80816 is fixed in Rhino 8 Service Release 6 Release Candidate
