AM79
FIle:
AM240679 Uwrapping not working.3dm (124.0 KB)
Unwrapping doesn’t seem to work. It does not delete the original UV mapping. Does the command need to reset/delete the UVs before execution?
Hi @AlanMattano,
I’ve logged a ticket for the developer.
In the mean time, we could use your system info, a file, and steps to reproduce.
Thanks,
– Dale
THx Dale
Windows Main and Secondary Display 4K resolution
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, build 2026-09-08
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5090 (NVidia) Memory: 32GB, Driver date: 7-22-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.88
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 10-18-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-22-2026
Driver Version: 32.0.16.1088
Z-Buffer depth: 24 bits
Total Video Memory: 32607 MB
C:\Users\a_mat\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
Alan, open up UV Editor select all objects there and click the Remove constraints button. That fixes the file. I don’t know why the custom mesh mapping has diverged from the constrained unwrap. Is it possible that a custom command has changed the mapping directly?
Also the object in that model has a wcs projected texture on its material. UV Editor tries to show that instead WCS projection instead of the mapping channel 1.
If you want to unwrap the object and use a texture mapping instead then you can open the texture mapping properties panel and click the “Click here to…”.
These should probably be handled:
Wow, that if anything destroys all models straight away permanently.
I think it’s the WCS projection that is causing this. Have you tried switching the texture to use a mapping channel instead?
