Bug: Unsplittable Surface
The large rectangular curve was piped with a .5mm dia. It failed to generate the corners. Trying to manually create the corners proved difficult because the surfaces cannot be split or trimmed.
Unsplittable.3dm (930.1 KB)
Hi Eric- the curve is short at the corner - if you move that curve end control point to the corner , you can trim.
Sorry, I assumed it was the same behavior I saw earlier. This is a bug in Pipe for closed curves.
