I’ve seen this once before many months ago, and now it’s popped up again. I can’t turn off the visibility of a Layer that has two sub-layers (both of which are turned off. Quitting and restarting Rhino did not help. Anybody else seeing this behavior occasionally?
The layer in question is “Scheme A”. In case it helps, I recall both the prior time and this time I had renamed the layers after objects were placed in them.
@dan: File is a client project and will be uploaded to your server, rather than attached here.
UPDATE: Restarting computer did nothing. Like before, only after selecting a number of different layers was I then able to turn off the desired layer. Definite (but probably rare) bug somewhere.
~Dave
Software information
Software versions
Rhinoceros version: 5.0.2 (5A865)
IronPython version: 5.1.2015.131
Language: en (MacOS default)
OS X version: Version 10.10.5 (Build 14F27)
Plug-ins
None
Third party kernel extensions
com.Logitech.Control Center.HID Driver (3.9.1)
com.Logitech.Unifying.HID Driver (1.3.1)
com.karios.driver.DuetDisplay (1)
org.virtualbox.kext.VBoxDrv (4.3.20)
com.paragon-software.filesystems.ntfs (313.2.12)
org.virtualbox.kext.VBoxUSB (4.3.20)
org.virtualbox.kext.VBoxNetFlt (4.3.20)
org.virtualbox.kext.VBoxNetAdp (4.3.20)
Hardware information
Computer hardware
Hardware model: MacBookPro8,3
Processor: Intel Core i7-2860QM CPU @ 2.50GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD Radeon HD 6770M 1024 MB
Memory: 1024 MB
Screen size: 1920 x 1200
Displays: Cinema HD (99dpi 1x)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Logitech: USB Receiver
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Apple Computer, Inc.: IR Receiver
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-1.32.25
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 6x
Mip map filtering: None
Anisotropic filtering: High
