Both RH 5 SR 11 and RH 6 WIP.
In the attached, when you use the cutter object to trim the main object, the result is that the main object is duplicated. If you shrink the object before trimming, this won’t happen. Also, if you remove the center hole and trim after that, it doesn’t happen
trim duplicates main body.3dm (650.1 KB)
