Bug: transform commands extremely slow in R8
Hello!
8.12.24275.15001
There’s a severe slowdown in R8 when translating many objects at once.
Testscene (DXF imported city map):
test map R7.zip (15.7 MB)
Moving or rotating everything takes 2-3 seconds in R7.
R8 locks up and does not seem to do anything. I tested with a small part of the objects, and it worked, but very slow. It doesn’t make a difference if commands are used, or the gumball.
Thanks!
Hold on, I’m testing if this is maybe VisualArq related…
Ok, no. Plugin is disabled, still slow.
Here it is faster, both the preview as well as the actual transform in Rhino 8. I will test in 8.12.24275.15001 as well
I don’t see a difference in 8.12.24275.15001
Can you post your full _SystemInfo?
I do see something different though, opening the file in Rhino 8. Seems that some block textfields are not being read.
Thanks, Gijs!
SystemInfo
Rhino 8 SR12 2024-10-1 (Rhino 8, 8.12.24275.15001, Git hash:master @ 032417c320544fc68e36107bfa74f69d316f7c45)
License type: Commercial, build 2024-10-01
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9261.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 SUPER (NVidia) Memory: 8GB, Driver date: 7-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.81
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2024
Driver Version: 32.0.15.6081
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\eugen\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\eugen\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\AdaptivePartsEnvironment\1.0.65.3\Rhenso.Ape.rhp “Adaptive Parts Environment” 1.0.0.0
C:\Users\eugen\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Garage\8.7.24140\net48\Garage.rhp “Garage” 8.7.24140.15431
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24275.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24275.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24275.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24275.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24275.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24275.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.12.24275.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24275.15001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
I’ve just tested again - still slow.
also all third party plugins disabled?
Hi Gijs, just for clarity. Who makes second party plug-ins as well as 1st party plug-ins?
Thanks, Mark
Those guys are hilarious. —-Mark
Yo, found it - it’s the APE (Adaptive Parts Environment) plugin.
Once turned off, problem gone. Well…
Thanks anyway!
that would be you?
