Bug: "The projection missed the selected objects"
When I try to loose project the blue lines onto the grey mesh, most of them fail to project. When I try to project only single one, this is the error:
Select surfaces, polysurfaces, SubDs and meshes to project onto. Press Enter when done ( Loose=Yes DeleteInput=Yes OutputLayer=Input Direction=CPlaneZ )
Projecting… Press Esc to cancel
The projection missed the selected objects.
projection missed.3dm (630.8 KB)
SystemInfo
Rhino 8 SR24 2025-10-8 (Rhino 8, 8.24.25281.15001, Git hash:master @ ba28668a8431990c700173e46ef2dbcb873cf092)
License type: Commercial, build 2025-10-08
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 48GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX Vega (AMD) Memory: 8GB, Driver date: 7-1-2025 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 25.8.1.250617
> Accelerated graphics device with 7 adapter port(s)
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 7-1-2025
Driver Version: 31.0.21923.11000
Z-Buffer depth: 24 bits
Total Video Memory: 8119 MB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.5.4.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.24.25281.15001
Projecting onto polygonal surfaces is unreliable (and generally bad practice).
This is due to tolerance issues at edges and corners. It’s better to create a clean surface that deviates only slightly from your mesh and use that as the projection base. Polygons might also contain errors, so it’s useful to simplify the shape. On the construction side, you also “modify” the surface before putting anything onto it. Polygons are for reference, not for modelling.
try projecting in the top orthogonal view downwards instead in a perspective view.
you will get much better results.
to build on what was said above, projected curves on a mesh will result in end connected polycurves made up of straight degree 1 segments.
inspect and rebuild these polycurves carefully for use in building surfaces from these projected curves.
Why would there be a difference between projecting in an orthogonal versus perpsective view when Direction=CPlaneZ assuming the the Cplane is the same? I assume the view direction is not or at least should not be involved with Projection unless Direction=View.
“reasons” are all I can give you… :wink:
I run into this often and projecting from an ortho view is always the fix.
I’d have to defer to someone smarter for the technical realities.
The problem is caused by the combination of Loose=Yes and the mesh as the target.
With the mesh as the target Project with Loose=No works as expected in both the perspective and top viewports. However with Loose=Yes the results are the same as @omichalek shows above.
I used ToNURBS to convert the mesh to an open polysurface with 20678 surfaces. (Note, the use of ToNURBS in this way is NOT recommended as a normal part of workflow.) With the polysurface as the target Project with both Loose=Yes and Loose=No works as expected.
This should be submitted for the developers to look at.
You might submit a bug report the next time you run into Project in a perspective viewport with other than Direction=View not working correctly while working correctly in the top viewport. I don’t recall ever encountering such a problem.
On the other hand if the Direction option is set to View I would expect different results.
this has been happening for so long (since I can ever remember) that I never project in the perspective viewport. But you are right, I’ll buggify it-
care to send in your file so I can use it as a failure case?
you can use our uploader if it’s confidential.
I don’t have a file with a problem using Project in perspective view. Also it is not a problem, based on my testing, with the orginal posters file.
