OK, at least one of the new bugs seen only in the BETA could be fixed. This gives me hopes for the other bugs, too.
As for the old bug (or behaviour) also seen in Rhino 7, I don’t understand why Rhino will refuse to release the active Gumball handle when I reach a blank space of a toolbar or hover over the Properties panel for a brief moment. Also, when the mouse pointer that drags the Gumball handle is over the Properties panel or a blank space on any other docked panel, and I release the LMB, the mouse pointer remains glued to the handle, so I’m forced to his Esc or press the LMB again.If the idea is to be able to switch some of the Osnap types, then this behavour should be specific for this particulr toolbar instead of happening on any other toolbar and UI element not related to the Osnap.
In some cases the arrow handle that was previously active remains marked in black as if it is still active, while in reality it’s released long time ago. And the control point is already moved to its new position. I can even hover over other icons with the LMB, rotate the camera and do other actions, but the handle is still marked as active (black) and I can’t grab the other handles unless I hit Esc or start a new command.
I know that Rhino is programmed to ignore an unwanted release of the handle to click on the snaps mid-action, but I talk about hovering over other panels or a blank space anywhere, then releasing the LMB there (on the blank space, outside the viewport), which triggers activating the handle permanently and inability to move the same handle anymore or select other handles.
Here is a new video with that behaviour. I recorded it in Rhino 7. As you can see, I’m able to click with the LMB numerous times, I can even move or close opened toolbars, but the Gumball’s arrow handle remains visually active (black), but the entire Gumball is frozen and I can’t select or move any handle afterwards. I had to disable all of my mouse tooltips, because the issue is even worse when they are visible:
There are a few unwanted behaviours related to dragging and hovering over UI elements, depending on what you press or release.
For example, here is another video that shows what happens in Rhino 9 BETA when I drag a control point, then I hover over a blank toolbar space, then I press Esc to cancel the drag while the mouse pointer is still on the blank space. Instead of cancelling the action, Rhino glues the mouse pointer to the handle forever and will not let me cancel the movement even if I press the Esc key multiple times afterwards. No matter if the mouse pointer is inside the viewport. The Esc key simply gets ignored. It’s not ignored in Rhino 7 and this bug only happens in Rhino 9 BETA. I can’t repeat this bug every time, but sometimes it happens.
If I press the Esc key in Rhino 7 while the mouse pointer that drags the Gumball arrow handle is on a blank space of any toolbar, the program cancels the movement and returns the dragged control point to its original position.
This particular bug that will not let me cancel the dragging makes the BETA feel quite clunky compared to Rhino 7.
