When putting it into a vaAnnotation object, the height parameter does not work. The text always remains the same height. In the GH script, it works, though. test GH vaText.3dm (51.6 KB)
Sorry!! I read your message during the weekend and I forgot to send you the link. I’m going to send you it now.
And yes, this version includes support for worksession. Real-time plan and section viewports will show section attributes on objects that are in a non-active document. Plan and sections views won’t show objects of non-active documents yet. I’m still working on that part…
The section line is not part of the villa file, of course.
However, I added a layout detail, and activated the section there → instant crash.
Something else:
It could make sense if section lines inside files loaded into the worksession would be listed in the section panel, and thus could be activated. Do you think this is doable?
Thanks!
I’ve fixed some bugs related to worksessions after I sent you the last build. But I’ll try to reproduce the crash activating a section on a layout.
Regarding enabling sections on non-active documents, this is doable, sure, but it requires some work in the UI panel. Let me check if it could be done for 2.12.
Hello!
It seems to be a problem with worksessions in general. When I attach a file, switch to layout space, and enter a detail, the attached file’s ‘main’ layer is greyed out (which it shouldn’t be). When I leave the detail again, Rhino crashes to desktop.
Will try to make it reproducable.
Thanks!
Are you sure?
When I attach a file, the ‘parent’ layer is always on by default. The sublayers visibility is taken from the file. Looks like so when I attach the villa in model space:
But besides that, Rhino became extremely fragile when working in layout details with attached files. Some bug must have been introduced in one of the most recent versions, because it was ok before that.
Just had another crash to desktop. Can you repro this:
attach the villa (or any other) file in model space
go to layout space, activate the detail
switch it to perspective
deactivate the detail again (doubleclick)
→ crash.
This might be unrelated to VisualArq… dunno.
Thanks!
I’ve finally reproduced the crash. It was a problem in the WIP build of VisualARQ 2.12 when a database was attached as a worksession document. It was It’s already fixed.
I’ll send you an updated installer in a few minutes!
