Well, as mentioned in the title, size of the text is increasing every time after Block editing is closed.
It has been a similar issue in WIP 20170926, as it seems - it is not solved.
Please see file enclosed.
ToMcNeel_TestBlock.3dm (48.0 KB)
Thanks,
Dmitriy
pascal
(Pascal Golay)
March 7, 2018, 4:48pm
2
@pascal @JohnM
Have you looked into this? Do you foresee this to be fixed in the next RC?
Thanks,
Dmitriy
Hello @pascal
Did somebody looked at this?
I guess this is a major bug.
Similar behavior I see now - I updated block, saved and closed Rhino.
After opening - text is small again.
Thanks,
Dmitriy
Again, @pascal @JohnM did anybody look at this major bug?
Thanks,
Dmitriy
I see it is rescheduled.
Can somebody look at this soon?
pascal
(Pascal Golay)
April 13, 2018, 5:23pm
7
Hi @Dmitriy - it looks like this is fixed in a parallel bug track item:
https://mcneel.myjetbrains.com/youtrack/issue/RH-41698
Hi @pascal
just checked the file I have enclosed in the first post - still not working. Text is growing in size.
Thanks,
Dmitriy
I’m still seeing the issue too.
It appears to be a problem with blocks that are scaled. If I work with an unscaled block the text is fine, but if I edit a scaled block and then the text starts growing, like the block scale factor gets applied each time I get out of the block.
Ian
To add to it I’m also seeing this issue with arrowheads in blocks
pascal
(Pascal Golay)
April 18, 2018, 10:27pm
11
Hi All - OK - tested 6.4 and ‘in-house’ 6.5… I can confirm that it is fixed in 6.5, and not, sorry, in 6.4…
