Please fix this asap because it is quite a big one.
There are two BIG issues:
-In technical view hidden lines thickness dont react to settings unlike for visible curves and silhhouetes which react to settings
-In technical view curves (not edges of polysurfaces) dont react to print width
In layout and print display on at least curves look ok thicknesswise but are not printed to pdf.
Providing a 3dm sample that we can look at goes a long way.
Are you printing to vector or to raster? Page size and DPI settings?
For the display in viewports, the Technical -> Objects -> Lines -> Hidden line width (pizels) setting changes the thickness of those hidden lines. Only the thickness, and not the spacing between segments can be set.
When printing views in technical display modes to vector PDF, the hidden lines are drawn based on the definition of the Hidden linetype. Here, you can set both thickness and spacing between segments.
if i was to be under oath i would swear i tested it and it did not work… strange things, but the other problem remains, normal curves under technical viewport dont have their thicknesses in pdf.
There are 3 objects in this scene. In the center is a closed polysrf with hidden lines. On the sides are curves with different linetypes assignments.
