there were many command boxes which could not TAB to change numbers before. i see that there has been some major improvement checking some other commands and tabbing through seems far more consistent. i did not check them all but i am happy how that turns out thanks @dan i think you were on that if i remember correct. if not thanks to who ever did that finally
ok, then i am actually a bit disappointed, since this was a massive pain. so there is nothing you will change to improve the remaining? i am using catalina by the way, but at some point i will hopefully have an m1 this year, no idea how big sur or whatever comes next will be then.
if i remember correct for instance rebuild surface was one example it went to the arrows instead of jumping to the next field, but i believe that was an issue in many other commands either
