Rhino 7 lets you switch the selected hidden and visible layers. You just need to select them preliminary, then hold the Ctrl key and click on one of the lamps to cycle between 4 different states:
- Layer A is on, layer B is off;
- Both layers are on;
- Layer A is off, layer B is on;
- Both layers are off.
BUG REPORT: This functionality is broken in Rhino 9 WIP.
Test 3dm file (V9):
Setback fillet fails on letter A at 2 mm radius.3dm (219.1 KB)
This feature must be well documented in the Help topics.
