Bug -Sweep1
From a toolbar button, the following -Sweep1 command do not read the rebuild/refit values correctly:
-Sweep1 Pause Pause Enter RebuildCount=5 Simplify=Rebuild ShapeBlending=Global Enter
actual value used is -2.14748e+09
-Sweep1 Pause Pause Enter Simplify=Refit RefitTolerance=.01 ShapeBlending=Global Enter
actual value used is -1.23432101234321e+308
Hi Eric- How are you determining the actual values? note Rebuild does not use a tolerance…
I noticed it because I was getting very heavy geometry with .1 refit tolerance selected. Those values I reported are from the normal run Sweep (minus the ‘-’ prefix). I just copied them from the text box because it always shows the last command.
Changing it from this:
to this:
-Sweep1 Pause Pause Enter Simplify=Refit RefitTolerance .01 ShapeBlending=Global Enter
fixed the problem.
