BUG – Surface extrude tapered, draft angle
In the BETA, Rhino seems not to like the integer, 3 in the surface extrude tapered, draft parameter. It defaults to a few decimal places larger…
Same situation is fine in V8.
Files attached
Thanks,
Draft angle issue-BETA.3dm (33.3 KB)
Draft angle issue-v8.3dm (33.2 KB)
System Info:
Rhino 9 SR0 2026-8-4 (Rhino 9 BETA, 9.0.26216.12303, Git hash:master @ 5ca1621d579933d7769ad5ce75f25b218981579e)
License type: Commercial, build 2026-08-04
License details: Cloud Zoo
Expires on: 2026-09-18
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.10
Hybrid graphics configuration using DirectX
Primary display: NVIDIA RTX A1000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 7-10-2026 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
- Laptop’s primary display device
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 6-17-2026 (M-D-Y).
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\KeyShotRhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.5.0.0\KeyShotRhinoPlugin\KeyShotRhinoPlugin.rhp “KeyShotRhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26216.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
I’m not seeing that here. Here’s one of the curves extruded once without and once with 3 degree taper:
@Gijs I tried in another session and it still does it at my end.. Other integers seems to input fine, but 3 still says 3.0000…000004
thanks @sach
I misinterpreted this bug report, I now see what you mean.
RH-97700 ExtrudeCrvTapered: decimal noise
