causes a flip rather than completing the command.
Categorized.
Please assign your new messages to the appropriate category.
Thanks
thanks.
Keep your shirt on, I’m getting there.
So, here so far, spacebar, on Mac, does nothing if the BlendCrv dialog is open. On Windows it completes the command…
well it flips the direction, you dont see that? anyway i guess it should just complete the command or is that not intended on the mac?
I guess I would expect it to complete the command, as an Enter.
i noticed that my flip 1 is highlighted which explains why it flips instead of completing the command, i can use tab to move the highlight but it is sticky and resets each time i use the command.
did you file a youtrack?
To state the obvious, pressing enter does complete the command. I understand you want space to complete the command and close the dialog.
I cannot figure out why Flip 1 is highlighted here and I’ve been poking around for far too long.
Logged here:
RH-62791 BlendCrv dialog: Flip 1 is highlighted by default
